1984 air cleaner hold-downs
Utah, USA
1984 Gray Coupe with CFI
My air cleaner assembly has the hand twist nuts that hold the top cover to the base of the air cleaner, sandwiching the air filter. I have two threaded posts on my throttle bodies, one each. How is the entire air cleaner assembly secured to the throttle bodies? I imagine it is a clip of some type. Where do I get the necessary parts? I have looked in my FSM, Chilton, and internet, but no success.
As I recall, there is a pair of sort-of oval shaped U-brackets with two bolts (10mm?) each; one on each TB. Underside has a vacuum line attached.
I, and others, have had some luck getting parts from vette2vette.:w
I know a guy who has the whole setup and may be willing to part with it.
PM me and I'll ask Rudy. :w
