GO_VETTE
Who said that Cross Fire Injection cannot work?
1.air pump has been removed.
2.alternator has been repositioned where air pump used to be.later model
3.relocated power steering by adding an 87 style power steering.
4.Intake mods:
modified the swirl plates to make them a bit more free-flowing.
Because of the wet flow the throtte bodies and the throttle shafts have to be modified. This is to let engine vaccum suck the fuel down into the manifold instead of the boot blowing fuel out path the throttle shaft
5.oil from pan to supercharger mods:
T fitting where the oil temp sensor was above the oil filter. The oil return from the supercharger drains back into the oil paner:
6.air filter/dump valve:
K&N air filter and a dump valve. The air filter was a tight fit so moved it back / up later with a aluminum pipe.
7.Air box mod: new cleaner
8. new badge required for air cleaner
Cross Fire Supercharged Injection
My Photos Photo Gallery - Photo 187 of 188 by NY - MySpace Photos
My Photos Photo Gallery - Photo 188 of 188 by NY - MySpace Photos
4.Intake mods:
