1984 Interior lighting question
  • Thread starter Thread starter ThunderGod66
T
ThunderGod66
I just got an 84 vette and I can't see the AC/Heater controls at all when it gets dark. Are they supposed to light up?
Yes they should. I assume it's similar to my 85. There should be two bulbs. Wire color code Grey and BLK. Once again, assuming it's similar to the 85.
Carlo
On an 84...just a panel ...no lights...The only light is in the button of the rear defroster if your car came with that option.
lights
On my '84 all the AC/Heat controls are backlit by a light that is very pale greenish-blue.
The panel is lit by 2 bulbs...you have to remove the center console piece then remove the A/C control to replace the lamps.
The panel IS backlit
2 bulbs!
Vig!
