aklim
Is the IAC motor on the throttle body?
Yes it is. You take the entire TB off and take the IAC off and then the few bolts for the IAC housing. Clean EVERYTHING, reassemble and try to reset it using IAC counts if you have a scanner and if not AND you are 100% stock, you can use the FSM method which someone will know about in a bit
