chris123
At what position on the HVAC control panel should vacuum be applied to the water shut-off valve? I sprayed it with WD-40, and slightly loosened the 1/4" bolt where the linkage pivots, and tested it with my vacuum pump, and it moves very freely, although no matter what position the slide lever is in (Max, Vent, Heat, etc.), there is no vacuum being applied to the black plastic vacuum line connected to it.........
Regards, Chris
Regards, Chris
