87vette16
New member
I am looking to change the gears from the stock 87 automatic to possibly 3:42 gears. Does anyone see a problem with that? Looking for a little more 'get up and go' from a dead stop. Thanks, John
You're right, I think it's 3:54 gears he's putting in.Idk that D36 has a 3.42 available. You will need to change speedometer gears. To calibrate speedometer. There is one on the output shaft of transmission the other is on the Vehicle Speed Sensor (vss) depending on what you need it's possible to have to change both gears and sensor.
