1988 Vette Rims And Rpo Code
L
LONNIE
DOSE ANYBODY KNOW IF...
1988 VETTE RIMS FIT ON MY 1980 VETTE?
ALSO IS THE OFFSET THE SAME AS THE ORIGINAL RIMS
AND WHERE DO YOU LOCATE THE RPO CODE NUMBERS ON A 1971 VETTE AND ON A 1980 VETTE ?
THANKS
vigman
Motor head!!!!
Valencia, CA,USA
LONNIE
STOP SHOUTING!!! turn caps lock off!
You will need adaptors to go from 1980 to 1988
I believe you could get the 87's on down to fit.
Offset's, dunno? Good bet their different.
RPO numbers... there is a sticker on top of the gas tank..( If it still there ).
Or join the National Corvette Museum, give em your vin # and some $$$$$
They will send you a copy of the orig sales stuff.
The more $$$$ you send the more info you get.
Mike
L
LONNIE
I LIKE THE CAPS I CAN READ THE TEXT EZER
WHAT TYPE OF ADAPTERS ARE YOU REFERING
BOLT CIRCLE OR OFFSET ??
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
Lonnie,
You're not the only one here that is reading your posts. Please do not use all caps in your posts. Thank you.
Tom73
Round Rock, TX
73 LS4 Coupe - 04 CE Conv
The adaptors adjust the offset. Believe that 17" is as large as you can go with std vette wheels. Can probably get something bigger in the speciality market.
tom...
