hyflyer
New member
- Joined
- Oct 14, 2015
- Messages
- 1
- Location
- Edgewater, Florida
- Corvette
- 1990, 6spd, stop me officer red coupe
I have a 1990 C4. base engine, 6 speed. All of a sudden it would
start locking out my ignition as if it where reading my key chip as
invalid and tripping the anti theft. 5 minutes later it would reset and I could get it started
again. Suspected key switch but it always read good. Then it just shut
down. No fuel pump, no turn over, nothing. Exactly as anti theft would
do but never reset. No codes from the ccm or ecm. Finally I changed
out the ecm and bingo it started and ran fine. I did see to dark pins
on one of the connectors. I cleaned them and hooked everything up and
all was well, for about 2 weeks. This is not a daily driver, but
after approximately 10 starts and stops it did it again. I had it towed
home and again no codes and everything appeared fine. I replaced the
ecm again and bang it started right back up. I am almost afraid to
drive it now as I dont want to get stranded somewhere. I will probably
buy a back up ecm so if it does happen again I can get home. I was
just wondering if anyone might have an ideas as to what to look
for/check that may be a cause for this problem. I do have 107000 miles
on it. I appreciate any help you can give me.
hyflyer
hyflyer
