Question: 1990 C4 Hazard light button is stuck in the on position.
Clarksville, TN
1990 white convertible, standard base model
My hazard light button is stuck in the on position. I tried to pull it out but it will not budge. Has anyone else had this problem, if so how did you fix it? Appreciate any help.
LLC5
Wa.
98 black 6spd convert.
Try taping off the area around the switch and use light silicone spray around the button, spraying in with the straw from the can. Work the button in and out and see if it loosens up, if not then it is probably physically broken and needs to b replaced.
Clarksville, TN
When I manipulate the multifunction switch I can feel it slightly move but it has not popped out yet. I will try it with the silicone spray and see if that helps out. Appreciate the info.
Clarksville, TN
Light silicone spray worked.
Hey Thanks again
I thought I was going to have to pull the steering wheel and replace that hazard switch but the light silicone spray worked like a champ. I was able to slowly work it free and it seems to be working ok now. Appreciate the help.
You are the Master Tech
