dperreault
New member
I have 1990 Corvette 5.7L Automatic, 22000 mile, that runs fine when I get on the gas but surges on slow idle and almost seems like it's going to stall. Come to a light or stop sign, I have to put it in neutral or park so the idle will be a little faster to solve the slow idle problem. This only happens when it is warmed up and the slow idle drops to 500 rpms. I replaced the following parts and the problem still exists:
ECM
Coolant temperature sensor
Throttle postition switch
Fuel filter
MAP sensor
Cleaned the throttle body
No codes are present in the ECM. I would appreciate any help you can give me with this problem
It has been suggested I replace the IAC valve. I can't seem to get it out. Any suggestions.
ECM
Fuel filter
MAP sensor
