georgekthompson
My 1990 Corvette standard started running sluggish 1 year or so ago. It only has 38,500 miles. Engine will rev to 6000, but not rapidly.
I have changed plugs, plug wires, tested module, coil, new cap and rotor. Fuel pump was changed in June, the new one was changed because the check valve was defective. Now the car is slow!!!! It idles good some times and other times I need another foot to keep it because it is rough and will stall, it then starts but not as easy as when it has been shut off after running good.
I checked fuel pressure today. No pressure after sitting from yesterday. key on 60lbs down to 25lbs immediately after the 2 second run and to 5lb within 60 seconds. fuel pressure 70lb at idle and drops slightly with bumping accelerator. Did resistance test on injectors but not the light test on wiring. Fuel pressure regulator vacuum tube did not have gas in it nor did it have gas odor.
What do I do next, thinking of changing the injectors since car sat for long periods prior to my purchasing 4 years ago, but it ran fine then.
I appreciate any info
George
George
