TODD L GRIFFITH
- Joined
- Jul 12, 2001
- Messages
- 1,120
- Location
- Middleboro, MA
- Corvette
- 99' MR Coupe, 04' Silverado 03' ZO6 Sold
To all of you that have a 4L60E automatic. Something real strange happened to my tranny. Under WOT my tranny would not shift from first to second and I would hit the rev limiter. If I backed off on the throttle, it would shift. This problem drove me nuts. All I needed was a pesky little Mustang to screw with me, and I couldn't respond. First I checked the fluid level, replaced the filter, added new fluid and the problem still existed. I thought the problem must be in the transmission, maybe faulty shift valves, modulator gone, thought it could be a the converter. I started to read the Chilton's, because the Haynes sucks for my car. I figured that the problem could be with the PCM. Upon researching the transmission in the book and online, there really isn't a whole lot of info. I did read that modulator pressure is effected by manifold intake vacuum. Sure as $#!% my MAP sensor was faulty. My MAP sensor was sending the wrong voltage to the PCM under WOT and the tranny modulator couldn't tell the shift valves that they neded to shift at the right time. The problem only existed under wide open throttle. Under normal driving conditions the problem did not exist. I think that this was because the voltage output of the MAP was normally in the voltage range according to the MAP sensor voltage specifications. My max voltage was only 2V between terminals A and B at 29.92" Hg. sea level, key on engine not running, instead of 4V. If this helps anyone I'm happy with that. If anyone has a comment, I would appreciate it. (The car does run alot smoother with the new MAP sensor. It wasn't really noticable until I replaced it. Time to by a scan tool I guess.)
