Help! 1994 Lumbar System Question
corvette94owner
New member
South Dakota
1994 Arctic White Coupe
Having an issue with 94 Coupe Lumbar System. When activating the switches, the bladders were not inflating...When I pulled the passengers seat....I noted that a hose on the lower part of the manifold was not connected...I reconnected that hose and all the bladders inflate,...when I "deflated" the bladders that same hose popped off the fitting...my question....Obviously that is not normal....is the fitting worn out or do I have more problems that that?
Image attached...
