Nucman
I have 2 questions, my vette has the electronic AC/Heat controls. My A/C works great but my heater blows semi warm air, never hot air. I have run a flush thru the heater core with a garden hose and get a very good flow. My engine temp runs around 210 degrees. I did notice that the light above the heater button sometime flashes and then stays on steady. I read that the controls need to be reset, I have pulled fuses to reset it and also disconnected the battery to reset it. Nothing seems to work. I had a overheating problem for a long time so the thermostat, radiator have both been replaced.
My second question is when I remove the top off my car and drive it, the body and front end seems to wobble alot.
Anyone had either of these problems ? any help would be appresiated.
