Nucman
Hello All, I have posted here before about this same problem and thought i had it solved but its back !!! I have a 95 vette LT1, that intermittantly says its overheating. I have replaced the radiator, thermostat ( new 180 degree) new radiator cap, kit to turn on fans at 200 degrees.
I still have a problem of where i get on the road for a hour or so and all of a sudden the analog gauge will start creeping up and then bottom out to 270 degrees but the digital will only go as far as 244 degrees, if I drive 1/8 mile down the road the temp will drop down to around 220 degrees.
I drove today from Baltimore to Norfolk Virginia, I guess about 200 miles. When I first got on the road the car ran about 205 degrees for a hour or so and then all of a sudden then temperature rose to 220 and then bottomed out at 270. About 1/8 of a mile it went back down to 212-215 for the next hour or so. I then pulled off the highway for food and and soon as i got off the ramp the tempurture rose again to 270 and then came down again. I got my food and pulled out of the parking lot and the temp rose to 270 again but after 1/8 mile came down again and stayed at 205. After driving a while the low coolant light came on but the car was running cool. I drove about 20 more miles and pulled of the road and went to check the coolant. The resorvare was between cool and hot, I twisted the radiator cap and the coolant started to rush in the resorvour, so I retighted it and just continued on. I got back on the highway and the car ran between 201-209 degrees for the last 80 miles of my trip. Has anyone else had this issue ??? I have no leaks, no white smoke from the exhaust, no water in the oil. I will say the heater never gets hot, just luke warm. Not sure if that is related.
