Doug
Q: When I bought my car in the spring, with 76,000 miles, the trans was quiet except for a little whine accelerating in 1st gear (probably a rough tooth). Now, @ 81,000 easy driving miles (I DO NOT abuse the car), there is an increasing whine at cruising speed, 3rd,4th,5th and final. Kind of a dry bearing noise, not real loud. Yet. When stopped, clutch in, no noise, but engage the clutch in neutral and the noise becomes audible and increases with RPM. At speed, shifting to neutral or depressing the clutch changes nothing, still have the noise. The unknown here is that my shop, at my request, drained and replaced the lubes in the trans and the differential so we could establish a base line for maintenance and also look for shavings. The noise started after the lube change. So, did they put too thin a lube in the transmission? Or not enough? Am I losing a front carrier bearing or what? Can I drain the gearbox and replace the lube with good old 90wt and an anti-gauling agent and save everything, or am I looking at a teardown? I'm not driving it untill I get this settled.
