Hi,I recently purchased a 1998 convertible with the dual zone climate control.The problem is when the heater is on,only cold air will come out the driver's side,no matter what temp. is selected and no matter what mode is selected-floor,dash vents or defroster.
The passenger side is fine and both sides are fine when the A.C. is used.The control panel lights up fine everywhere and on both driver's and passenger's side the temp. numbers will increase and decrease as selected.I looked under the dash to see if a duct door was not opening or closing but nothing was really visible.A check for codes was done with a Snap-on scanner for both current and history BCM,engine,trans.,and antilock codes and the only thing stored was a BCM history code B2723 Passenger Key Detection Circuit Open/Short but I don't see how that would apply.Has anyone had a similar problem?Thanks very much for any tips.
