tnovot said:Two bolt engines are supposedly fine for street use and can handle up to 400 HP.
Ken said:You'll be okay Edmond. If you decide to go four-bolt mains, you can always get a splayed set-up from one of the aftermarket manufacturers, but you shouldn't need it unless you're gonna boost it or spray it.
kenwa said:Edmond, if you want a little extra insurance, install a set of ARP 2-bolt main studs. $35 a set, or $50 if you've got a windage tray. You'll need to align hone though.
Your topic caught my eye because I just bought a set of 2-bolt ARP studs for the 400 small block I'm building. Actually $38.95 from Summit. You probably have a windage tray in yours though.Edmond said:I'm going to check my Summit catalog today for that. Thanks for the recommendation. Everyone sings the praises of ARP products so it must be for a good reason.
Moonunit 451 said:You'll be fine with the 2 bolt, I think I saw you were goin' 383. It's done all the time, some folks "splay" them which is said to be stronger than the 4 bolt, but for street driving, not neccesary
ALL year's for drivin' my car, she's no garage queen
Moonunit 451 said:Should be NO problems then for sure. What are you gonna do for a cam and intake?
Vettefan87 said:I have thought about roller rockers for mine. I have seen on summit they offer two 1.6 ones and 1.52. What is the difference between the two of them? And what ones should I get and what price range am I looking at the ones on summit are like 192.
