Fred@ReverseLogic
The popular Race Ramps 56" and 67" service ramp models have a constant incline of 10.8 degrees. This incline angle, which is 6+ degrees less than typical auto superstore ramps, works for most modern cars. For cars with a low approach angle, Race Ramps offers optional XTender ramps which reduce the initial incline to 6.8 degrees.
Since 2011, Race Ramps has been making custom 2-stage incline ramps for Reverse Logic. The 2-stage incline ramps are basically the equivalent of the 56" and 67" ramps with integrated XTenders. The platforms are 30" long for both the constant incline and 2-stage incline ramps. The RLL-72-2 and RLL-87-2 incline sections have an initial slope of 6.8 degrees which transitions to 10.8 degrees for the last 6" to 8" of the incline section. The 2-stage incline ramps are less expensive than the combination of the constant incline ramps and the XTender ramps. They are also more convenient to store and use.
The RLL-72-2 ramps are 72" long by 12" wide by 8" high.
72" 2-stage incline ramps
The RLL-87-2 ramps are 87" long by 14" wide by 10" high.
87" 2-stage incline ramps
In 2013 Reverse Logic introduced the 2-stage RLL-80-2 Race Ramps. This ramp model features a cradle top platform and an invertible incline section which can be used as a trailer ramp. In order for the incline section to be invertible, the transition from the 6.8 degree incline to the second stage incline was moved from the incline section to the seam between the incline section and the platform.
Cradle top platform 80" 2-stage incline ramps
