hoosierdaddy
2000 C-5 Coupe window leakand/or adjustment
I have a slight leak on the dirvers side door just to the rear of the front side of the seal right around the curved part that deverts the water down the front window seal; of the rubber drip trim or rail, any idea on what I should try first? :confused I guess I think that this may be just be a top adjustment or something on the latches. Is there any particular procedure for adjusting the latches on the front and the middle one in the rear of the removable roof panel? I also have the right side door window hitting slightly the clip (I think it is called the blow out clip) will a top adjustment take care of this. I dropped the origial roof panel so this is new and thought maybe I never got it adjusted right. Any help on this would be greatly appreciated.
Thanks,
Bill
Thanks,
Bill
