Technical Bulletins FROM THE GM base
Engine Knock or Lifter Noise (Replace O-Ring) #02-06-01-038
2001-2002 Chevrolet Camaro
2001-2003 Chevrolet Corvette
2001-2002 Pontiac Firebird
2002-2003 Cadillac Escalade, Escalade EXT
2000-2003 Chevrolet Suburban, Tahoe
2001-2003 Chevrolet Silverado
2002-2003 Chevrolet Avalanche
2000-2003 GMC Yukon, Yukon XL
2001-2003 GMC Sierra
with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, Z, G, S, N, U -- RPOs LR4, LM7, L59, LS1, LS6, LQ9, LQ4)
Condition
Some customers may comment on an engine tick noise. The distinguishing characteristic of this condition is that it likely will have been present since new, and is typically noticed within the first 161-322 km (100-200 mi). The noise may often be diagnosed as a collapsed lifter. Additionally, the noise may be present at cold start and appear to diminish and then return as the engine warms to operating temperature. This noise is different from other noises that may begin to occur at 3219-4828 km (2000-3000 mi).
Cause
The O-ring seal between the oil pump screen and the oil pump may be cut, causing aeration of the oil.
Correction
Inspect the O-ring seal and replace as necessary. Use the applicable part number listed below. Refer to the Engine Mechanical sub-section of the appropriate Service Manual.
Parts Information
Part Number
Description
Qty
12557752
Seal-O/Pmp (O-ring)
(F and Y Cars)
1
12563963
Seal-O/Pmp (O-ring)
(C/K Trucks)
1
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Usage
Labor Time
J1060
Pickup Tube and Screen - Replace
F Car
3.7 hrs
Y Car
4.3 hrs
C Truck
1.3 hrs
K Truck
2.1 hrs
Needle Bearings Found In Oil Pan (Replace Rocker Arms) #02-06-01-029
Needle Bearings Found in Oil Pan (Replace Rocker Arms)
1998-2002 Chevrolet Camaro, Corvette
1998-2002 Pontiac Firebird
2002 Cadillac Escalade, Escalade EXT
1999-2002 Chevrolet Silverado
2000-2002 Chevrolet Suburban, Tahoe
2002 Chevrolet Avalanche
1999-2002 GMC Sierra
2000-2002 GMC Yukon, Yukon XL
2003 HUMMER H2
with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, G, S, U -- RPOs LR4, LM7, LS1, LS6, LQ4, LQ9)
Condition
Some customers may comment or technicians may notice needle bearings being found during an engine oil change. The bearings may be found in either the drain pan used or on the magnetic oil pan drain plug.
Cause
One or more rocker arms may have experienced a bearing failure.
Correction
Inspect all of the rocker arms for bearing retainer cap failure. If one or more defective rocker arms are found, replace all 16 rocker arms. Refer to the Engine Mechanical sub-section in the appropriate Service Manual.
If no condition with the rocker arms is found, refer to the service history for previous rocker arm repair. If previous rocker arm repair was made, then the engine may not have been thoroughly cleaned of loose roller bearings. If no previous rocker arm repair was made, then look for another condition.
Remove the oil pan and clean out any additional bearings found within the oil pan. Refer to the Engine Mechanical sub-section in the appropriate Service Manual.
Install the oil pan. Refer to the Engine Mechanical sub-section in the appropriate Service Manual.
Parts Information
Part Number
Description
Qty
10214664
Rocker Arm
16
12560696
Gasket - Rocker Arm Cover
2
12558760
Gasket - Oil Pan
1
Labor Operation
Description
Labor Time
J0357
Rocker Arm - Replace - Both Banks
Use published labor operation time
J1000
Pan and/or Gasket - Replace
