mikemikeover
New member
I just replaced the clutch(ls7 style), release bearing, pressure plate, pilot bearing, slave cylinder.
The car starts up perfectly, no leaks, and I bled the clutch multiple times.
I can't shift between gears when the car is running. Sounds like it will grind if I try to force it. When off, I can shift from 1,2,3,4,5,6.
I can start the car in 1st and slowly release the clutch and the car will move just like normal. There is no lurching. With clutch in, you aren't getting it into 2nd without turning the car off.
I give up...
I give up...
