Chuck K
New member
2005, Z-51, 6speed, 22k miles
Driving the other day, I used full throttle on entry ramp (3rd gear) but not high rpm's, up-shifted and thought I noticed that the rpm's increased abnormally between shifts. Figured it was my imagination. Then it happened again when at full throttle, not my imagination.
Later on return trip the same thing happened again, this time also after brief full throttle but this time the up-shift did not cancel it. Took it out of gear, the engine was racing, (thank you Chevy for the rev limiter !!!) shut it off and pulled over. Restarted it & engine raced. Shut it off, repeated restart 2 more times, engine still ran up to full throttle. When shutting down the engine shook/vibrated a little strangely when almost at zero rpm's. Finally, I opened and shut the door, restarted and all seemed normal. (can't imagine that there is a connection with the door). Drove home cautiously. Obviously I am more than a little nervous about the next time I put my foot to the floor!
Has anyone out there had this happen with the 2005 LS2 or similar??
Any suggestions before I take it to the dealer for what might be expensive guesswork??
Thanks !:ugh
Thanks !:ugh
