M
Mikey1
I have a problem that many people know about....I fell that the "mark of excellence" is just getting a bit too large by now.
Since i still have to replace the oil pan gasket...which i will do in some 2 weeks time and add the 6qt oilpan I thought it would be a good idea to replace the rear main seal.
I thought there might be some replacement out there that helps getting the leaky stuff inside....something like a heavy duty version with two lips instead of one....
...I have found versions for align honed situations....but am not sure if this is an alternative if no work has been done and the crank is just a little worn (don't know the correct expression....) but not yet on the level to be machined.
I am very interested in any experiences...
...engine is stock 327/365HP
