3.42 top speed
  • Thread starter Thread starter c5blue
C
c5blue
is there any top speed lose'n if i use 3.42 dife. ???
and what is the best headers has loud sound ?????
Need Info to help you!
What are you driving?
I assume that it is a stock C5 with an automatic transmissions????
If this be the case, you either are starting with a 2.79 or 3.15???
Either case you can expect top end to be reduced. I know of only one group that has tested an automatic tranny with a 3.15 rear axle. Top end was 161mph.. Moving to a 3.42 will drop top end to around 150mph give or take a few miles per hour.
This is based on the other groups numbers. Hope this helps you.
Stan
I think you meant 2.73, not 2.79. Close, but...
