L
lnirenberg
I found the OEM shoulder harnesses useless at best and frustrating always as they constantly slipped through the sash guide back to the retractor. One of this winters projects was installing a more modern setup. I got the seatbelts at:
http://store.yahoo.net/wescoperformance/seatbelts.html
I don't remember what they cost but it was relatively inexpensive. A bit of luck in that the male side fit into the OEM GM logo female buckle. The ones in the kit were let us say s***. The problem with this type of belt is that the male buckle is too large to fit through the front and back sash guides built into my coupe's seats. They did, however, fit through the seat opening with the upper trim pieces removed. A small and relatively unnoticable slot was cut in the corner of the front and back trim and the belt was slipped through this so that the trim could be reinstalled. The belt itself anchors in the same place as the OEM seat belt and the take up fits nicely under the rear compartment trim. The color contrast between the tan seatbelt material and my dark saddle seats is not as striking as it looks in the pictures as I used a bright flash on this gloomy day:
