M
milkdud99
hey (if youve read my other post) my car is getting better.. its soo close. i think i narrowed down the problem, but i have a question
when the car idles, it sounds like every so often a plug isn't fireing. so i tested all of the wires, and they each hae electrisity going threw them. then i started the car, and pulleg the spark plug wire from the #1 cyl. and the car got ruff. so i figured that worked (my thinking is, is that if the car has no change in sound, that the plug on that cyl. is bad.) Well i went around to all 8, and found that pulled the spark plug wire off the #2, #3, #5, and #8 plugs the car made no difference in sound. ok so i figure i had a bad batch of plugs.... but to back this up, i pulled the plugs from the #2, #3, #5, and #8 cyl. each, and made sure that each plug was sparking (which they all are)...
I even pulled the wires from the 2,3,5,and 8 at the same time, and had no change in idle????
Im confused... and convinced that this car is possesed!
Is there any reason on why these cyl. with no power to the plugs are having the engine at a smooth idle??
