goingballistic
Ladies and gents been off the board for a while due to work but bakc again.
As some of you are aware I'm building a 383 stroker for my '81 and made quite a few strides......much research, engine desingers involved etc.
One question they can't help me with is this:
I am planning a high volume oil pump not sure the cfm YET but the question is what size pan can you put on the block and stay clear of the frame ( ie no mods to the undercarriage) so the engine just drops in with the new pan. Part numbers would be greatly appreciated if you have dealt with this.
I decided to stay with the 5.7 rods due to the attack angle in the cylinder. With a 383 crank this required a custom grind on the cam and some modifications to the block to accomodate the rod bolts on the rotating assembly, basically clearing casting off the block so the bolts don't hit. THere is about 50 thous clearance between the rod bolts and the cylinder shoulders and also the rod bolts and the cam lobes.
So step one is complete, clearing the rotating assembly, so the engine is apart again and is now ready to go the shop for zero deck, 30 over etc.
Any help or guidance here would be appreciated. Thanks.
Paul.
Paul.
