8
86vetter
I have a 1986 vette with the 4+3 trans.1)When it is cold out it takes about 3/4 mile before it goes in to overdrive.2)It will only change to overdrive when the shifter is in 1st gear.3)It will only go into overdrive in other gears when you hit the button hard a couple of times.I'm going to order the filter and gasket,but i wanted to see if anyone else had this problem.Thank you for any input
