D
DrBecker
Hi all,
Im new to vettes and i just got a 88 with a 4+3 transmission. Prob is, it will not shift into any of the overdrive gears. Sometymes when letting off the gas going 55, the trans seems to be locked to the motor and other tymes, i can let off the gas and it seems as though the trans is not hooked up to the motor....kinda like it just is freewheeling...darn it is hard to explain... sometymes the light on the speedometer (the "D") for overdrive is on, and other tymes its off, but anytyme i try the switch on the shifter, it does nothing... one tyme the overdrive kicked in...but most tymes im driving the thing in 4th and at 2900 or 3000 rpm. I live out in the sticks (closest McDonalds and walmart are 90 miles away) No one here can help...could it be just a simple switch gone bad? What could I check out before it goes to the dealership...The only chevy dealership close to here has a REALLY bad reputation Help! By the way... im 90 miles from Witchita, Kansas...Does anyone know of anybody out this way where Im not gonna get the shaft when taking the car to get fixed?
Thanks Much,
Doc
Thanks Much,
Doc
