4 way flasher and turn signals
Mikei16
Poughkeepsie NY
1982 T top white + 1980 Red Vet + 1978 Siver Vet
1978 corvette, 4 ways work, but the turn signals blink very fast. The turn signals worked real slow and would almost stop, I installed an electronic flasher and it seemed to be ok, but now the turns blink very fast. Thanks for any help..
Mike
turn signals blink fast after putting in an electronic flasher????
Sounds like the new electronic flasher is not working.
Maybe replace with a normal 552 flasher?
:w
I found the problem!! I was replacing the flasher under the center console and I guess thats for the alarm? The one that needed to be replace was up under the right side dash above the AC vent duct. Its works ok now.
Mike
I believe the flasher in the middle is for the 4-way emergency flashers.
Glad to hear you found the problem.
Thanks for letting us know.
:w
