TODD L GRIFFITH
- Joined
- Jul 12, 2001
- Messages
- 1,120
- Location
- Middleboro, MA
- Corvette
- 99' MR Coupe, 04' Silverado 03' ZO6 Sold
40BMS B2723 Won't Start
I got this code after taking my Z out for a test drive on new fuel injectors. It is a passkey detection circuit code out of the body control module. I was doing some tuning and set the alarm off either accidently, or it was triggered. I'm not sure because the key fob was in my pocket and I may have activated the panic button, not too sure. I couldn't shut the alarm down right away, so it drained my battery some. I recharged the battery and the code remains 40BCM B2723, with a no start condition. I went through the dic and with my scanner and cannot erase the code. (*****!) The check engine light is on and the security light is steady with the key in the on position. I do not have another key with the resistor, but took the key to the dealer where they have a lock cylinder simulator and the resistor is good, and shows the key code. When I try to start the car all accesories light up, and the fuel pump runs, with the key in the on position. When I turn the key the rest of the way for start, everything seems to die, no starter or even a starter click. I'm also in the stupid column lock, and it will not back off, but no column lock code is present. I have an appointment with the dealer Monday. It most likely is a worn or broken ignition cylinder circuit for passkey. If anyone knows anything else, or have been through this before, please let me know. Maybe save me a trip to the dealer and a tow. I know these map glass batteries have to have a good charge. It may seemed charged fully, but I know that this VATS system is a finicky bastard. Any ideas, glad to hear them. I tried a passkey relearn just in case, but with the code present it is useless.
