- Moderator
- #21
- Joined
- Nov 9, 2000
- Messages
- 7,536
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
If you want to keep the Powerglide that should be no problem. The Pg was the automatic trans in both '66 and '67 Corvettes with hydraulic lifter big blocks. In '66 both the 427/390 (L36) and the 427/425 (L72) were rated at 465 pounds of torque. The difference being that the 390 horse was rated at 3600 rpm and the 425 was rated at 4000 rpm. With the size of tire you will be able to put under a stock midyear body you will loose traction long before you break the trans. It will take a lot of hard starts and just plain abuse to distroy that Pg if it's in good condition.
If you have any doubts take it to a trans shop that builds racing transmissions for a high performance rebuild. Keep in mind that the Pg is one of the most popular transmissions in many classes of drag racing including rails and gasser type cars. You will find them behind almost any engine you can think of, even big block Fords and Chrysler products, that are making huge hp and torque numbers and hooked up with big slicks. They use them because they are durable and with only 2 speeds their times are more consistent.
You didn't mention what your Corvette guy was going to give you with that 454 build. What parts are he going to use? What kind of hp and torque numbers is he talking about? Is he figuring on hooking it to the Pg and building it accordingly? A 427 and 454 look the same on the outside so you could dress the 454 up in origional 427 accessories and it would take a numbers guy to tell the difference. In this case numbers don't matter anyway. The 427 has better high rpm potential but the 454 makes it's grunt lower where you do 99% of your driving. Also 427 builders are harder to come by these days. I suggest you take a few rides in some built up 454 cars too. Back in the day I had a '70 El Camino SS 454/450hp LS6. I shifted the M22 between 6000 and 6500 normally and quite often at 7000 depending on the heat of the moment. It's all in the build.
The '73 -'75 454 passenger engine is a good builder. The low power numbers of these engines in stock form don't mean a thing once you tear them down and start building from the bare block. Take a look at the specs for that 454/425 crate engine. It will run on regular unleaded and idle like a stocker. The crate 572/650 horse is said to idle smooth while burning pump gas. Big cubes, lower compression and proper camshaft and head selection are the key. How about the Viper or that V16/1000hp Caddy concept car. It's loud but smooth and can be fueled at the pump.
No matter how much technology improves there is one axiom that remains constant. There is no substitute for cubic inches.
Tom
Tom
