50th AE Sequence Number?
W
webxfx
Does anyone know if there is a list somewhere out there, showing VIN to Sequence Number of AE cars.
And don't send me to 50threg.... cause that not the Sequence number, and the database seems incomplete
5,800 feet above sea level
2006 'Evil Stealth Black' Roadster
If I'm understanding your request, you want the VIN numbers of '03 AE edition Corvettes in some sort of list, sorted by build date? So that you could find, I'm guessing, that your AE Vert is No. "x" of "y" built?
Hmm...
I'll be honest, that's a pretty specific list. The only resource I could point you toward to get something that specific is the National Corvette Museum. AE Corvettes, to extent that anyone kept lists that specific, would likely be stored there.
-Patrick
W
webxfx
You got it.... is it 7xxx of 11xxx made....
there is that C5/C6 registry site, anyone a member? does it have that info?
yellow_2002_germany
Kokomo, Indiana
2006 Velocity Yellow
I believe the sequence number is on the build sheet. The sequence number takes into account the number of pilot vehicles built at the beginning of the run.
However, I do not think there are any databases anywhere which take into account specific option numbers built. The only way to do that would be to see ALL the build sheets and do the numbers manually.
Good luck in your quest.
W
webxfx
that sequence number is just, out of "all" 2003 built...
I was on the site Z16.org and amazed on how well that was put together, kind of looking for that kind of info on the 50th AE cars
abowtieguy
Calgary, AB. Canada
2004 ZedOh6/Zed16 Commemorative Edition #482
I know this was asked quite awhile ago but did you try the 50th AE site? http://www.50thregistry.com/ Maybe the answers you seek are there.
Good luck with your search.
