56 & 57 2 x 4 air cleaners dimensions
street_rodder
Minneapolis
1954 old drag car
I have a stock Vette 2 x 4 intake with WCFB carbs installed in my 54 Vette. I used hot rod motor mounts due to a MustangII front end, & now I am not sure if I have enough room for the dual filters to fit under the hood. I have already removed the X brace across the inner hood. I need the actual height from the mounting surface to the top of the filters. I really hate to order them & find out they won't fit!
Sorry No ones given the answer yet, I am just trying to think who here has a daul quad car.
Best of luck with your project
Mine are 2 3/8" from bottom to top of filter. Took one off the car to check. The center is recessed so the wing nut does not extend above the 2 3/8" height.
Hope this helps,
MCMLVII
