I have a 85 coupe. I was replacing interior lights. The passenger side floor lamp requires a 563 bulb. I just bought two new ones. I have power to the circuit (tested with 12v test light). When I install a new bulb, there is no light from the bulb, but when I check the circuit, there is power on both sides. In other words, the filament is not broken...power flows through it.
I have checked the bulbs with an ohm meter...shows no resistance.
I have cleaned the contacts on the bulbs and socket. The bulbs still do not light up.
My battery shows proper voltage, but still no light. The glass on the bulbs appear intact. Why would they not light up? I've never seen this happen before. What gives?
