63 Restore
  • Thread starter Thread starter k5blazer87
K
k5blazer87
Hello
I am looking for Block # 3782870, Head # 3782461, Intake #'s 3799349 or 3844459. Any help or direction would be great! Thanks
I have a pair of head's CHEEP!
After market aluminum edlebrock manifold...
One side had a small crack which I had nickle welded & pressure tested.
They have been machined/ new valve seats (2.02/1.60)
there's a pix here SOMEWHERE...
461 castings... stock studs.. I have other parts as well
Most of the factory rockers/pushrods/ aftermarket cam & lifters ( numbered )
GM double roller chain...correct harmonic balancer, Chevy rocker covers...tin
E mail for details
vigman@earthlink.net
U Might Try Engines Limited
K5blazer87,
If you're in the market for correct dates etc and looking for a matched engine you can check engineslimited.com. in Wisc. Someone told me they can put together a matching numbers engine with the correct dated block, intake and exhaust manifolds. Hope this helps. Save The Wave!!! :beer
