M
milkdud99
ok i think my engine is possesed!
I recently took apart the engine my great working 327 300 hp vette. Got it bored to 60 over, new pistons, put the new valve guides and seats in it to run unleaded fuel, new high performance oil pump pushing 60 psi at idol, new cam from crane(113942), new lifters and pushrods, new timing chain and gears, new fuel pump, rebuilt the carter AFB 625 cfm carb, new spark plugs gapped at .035, new taylor spark plug wires, new mallory distributor, new ignition coil, new valve spring which are 125 pounds, and a turned down crank! the problem is, it has NO power like it had before. After timing it 8 deg advanced and adjusting the rocker arms, it feels like my 77 beetle could kill it and that only has like 85 hp or someodd!
Its weird... it purs like a kitten at idol and when free reving it, although it does have a very very very slight lag in the carb. but when it goes for a drive on the road... it goes no where!!!
i have tried to think of everything i can do....i NEED HELP!!!
One guy at crane said it might be too much cam for the car, and another guy said it should be running just fine.......
original cam
New cam
I Dont know what to do to get this thing runnin great
any ideas i would greatly appreciate!
original cam
New cam
