Ol Blue said:JohnZ mentioned to me that for drum brake cars one could use a dual master cylinder from a drum brake Camaro. From what I understand, the disk brake master cylinders have a residual valve in them that helps keep the brake pads close to the rotor. Maybe ZIP has that problem covered when you tell them you want a dual system for a drum brake car, but you might want to really push them to answer the question.
Ol Blue
