rick f.
New member
i have a rough idle and a slight misfire when cruising. sputters when pulling away from a light but seems to run fine under a load. switched carbs and still does it. changed vacuum advance and noticed that the rod that fits into the breaker plate is a little loose. i can move the breaker plate a little bit by hand is that normal? exhaust smells like unburned fuel. gonna adjust the valves my next step...any insight? thanks
