C
chipster
I just purchased ignition shielding from Corvette Central for my '66 427/390. I have reviewed my trusty "assembly manual" but I am still confused as to how to install. It shows it attaching on one side via an "existing screw"? Where is the "existing screw"? The other side appears to attach via one of the two bolts that attaches the coil bracket to the intake manifold. Is that correct? If so, which one of the two bolts do you use?
