66 Roadster For Sale
RayO
New member
Roswell Georgia
1966 Roadster. White, Red leather Interior. Solid Frame and birdcage.
Original Atlanta car that has been in the South since new. Glove box removed to check birdcage. No rust detected. The car does not have the original paint job but it is the original color. Good driver quality paint. This is not a a show car / Duntov award winner / NCRS corrrect piece as it stands now. If that is what you are looking to find this is NOT the car for you. Car is located in Atlanta.
This car is a clean mechanically sound DRIVER. Price will depend on how you want the car delivered. As noted below I will sell the car in a couple of different configurations so price depends on what you want. I am thinking a price around $39.5, higher if you want both engines. Price also depands on which engine you want in the car at delivery.
350 CI motor currently installed in car. Car can be purchased with ORIGINAL 327 reinstalled OR with 350 CI as currently installed PLUS 300HP ORIGINAL motor along side on a dolly. The 300 HP 327 (unbroached and original std bore) is not installed I will reinstall the original engine and trans if the buyer so desires.
If buyer wants the car without the 350 but with the 327 uninstalled I can do that also. Original motor needs a rebuild BUT it is standard bore and it is not broached. It ran when I removed it but it is getting rather tired. Heads (correct castings) are off right now so bore can be verified.
350 Motor has the following parts :
NEW Trap door GM oil pan
NEW Fuel PUMP
NEW Edelbrock Heads Heads giving Approx 9.8 / 1 Compression
NEW Steel GM Crank
NEW GM Pink Rods
NEW Oil Pump
L-79 461 Intake Manifold
NEW Comp XE262 cam and Crane Lifters.
NEW late Model GM finned aluminum Z-28 and LT-1 Valve Covers
MSD 6AL and MSD Billet tach drive distrib.
NEW GM 4 Bolt Engine Block (non Bowtie)
NEW GM flywheel
New GM 8 inch Balancer
NEW TRW Forged Pistons ...from 1970 LT1 / Z-28 360 HP engine
I have many but not all receipts for all these parts.
Other Original Parts included:
Radiator
Distrib.
Rear end 3.31 Non Posi (Currently installed In car)
Original 4 Speed
66 rocker moldings
Hardtop. Needs seals and new headline. Window is OK
Soft Top...complete, uninstalled frame ....needs new canvas / pads.
NOS Ammeter (not installed)
Original Intake manifold. Needs a couple of Helicoils on carb studs.
Alternator
Original open element air cleaner.
All ignition shielding (Except for pieces along block sides)
Non Original Parts:
Replacement shocks. Standard parts house stuff no magic goodies.
67 Dual master cylinder and lines
67 Vette Rocker Mouldings
Rally Wheels
Griffin aluminum Radiator
4 New Eagle Radials
15 inch wheels (Wheel Vintiques)
New Rear Spring
NEW 2.5 Inch exhaust front to rear (I have original 2.00 exhaust manifolds ))
Hurst Shifter for both / eather transmission(s)
NEW Stainless Steel Parking brake shoes springs etc etc.
Richmond 5 Speed
New GM Replacement Heater core..not installed.
New tach drive cable (with 90 degree adapter)
Original Parts NOT available:
Master Cylinder
Carb
327 300 HP valve covers
2.0 inch Exhaust pipes behind the manifolds. I do have the manifolds.
Bias Ply Tires
Car needs:
Carpets, especially in front
Training arms likely need refirb. They are untouched originals.
Soft Top Installation
Hard Top Rebuild / Resto
Heater core installation
Pictures on request. Hpexpatriot@yahoo.com
