zr1vp said:My radio has been acting up so I dug into it and found the cable to be defective. What's the procedure/secret to replacing it? Loks like a pain in the neck.
Maybe if you can spray some WD40 or some kind of lubricant around the edge of the grommet it might come out easier and with less or no damage. Just a thought. Probably better than forcing it dry. Think that will help Bob?67HEAVEN said:The two hardest areas will be in removing the metal runner (under the carpet) along the driver's door sill (the cable runs through it) and the rubber grommet at the rear bulkhead. The grommet can be very difficult to remove without damaging it.
Other than that, it should be a piece of cake.
The total procedure only took maybe an hour. Threading the pin end of the cable thru the grommet was a piece of cake. Thanks for everyone's help.zr1vp said:Thanks fellas. I'll post the results after the task is completed.
