Eagle Flight
- Joined
- Apr 12, 2003
- Messages
- 48
- Location
- Houston, Texas
- Corvette
- 1967 L79 C60 M20 Coupe, 2004 CE Z16 #1864/2025
I need some help, I recently got a '67 coupe :s , everything works great except the horn. I've checked the grounds and replaced the horn brush/spring in the steering column, I see good current and contact in the steering column, so I suspected the horn relay. Checked the fuseable link that connects to the relay and it is still good.
Got a new relay from Corvette Central and it has an extra connection in the middle of the body that the old one didn't have. (old one had the green horn plug-in connection, a black small wire plug-in connection, and the 2 screw in side post wires, one with side crimped red wire and one marked 'batt' with a straight crimped red wire - the old relay also had the separate fuesable link wire tied in at the bolt on terminal with the side crimped red wire, so I put it the same way). :confused
Hooked it all up with the new relay and no joy.
Since it did not work before, I have little confidence in the original config and do not know what to do with the extra connection point on the new relay either. I have the service manual wiring diagram but it doesn't help much either.
;help Anyone out there had horn problems or able to help? Without the horn I cannot pass a safety inspection in Texas, so can't really drive it around much... (potential $40 ticket :cry )
