427/390
After taking the '67 BB Cpe out of storage this June and taking it for the summer's first ride, I immediately noticed that it pulled to the left when braking. The car got all new calipers, rotors, stainless steel braided lines and master cylinder about 7 years ago at which time I also switched to the Dot 5 silicone brake fluid.
My first guess (emphasize guess) was that the brakes needed to be bled so I found the time last weekend for a gravity bleed. I also examined the left front caliper and cleaned it with brake kleen. Had someone step on brake and it mostly looks ok BUT one of the pistons seems to be a little tight (e.g. doesn't release fully) - So, if I have the car on jack stands I can feel a slight drag on the left front when compared to right front. Some suggested that the flex hoses were to blame but the vendor I bought them from claims that is probably not the case as they are the braided stainless versions. The vendor also claims the caliper is fine because brake fluid comes through the bleeders.
I checked the suspension to see if anything was wrong, but the car rides and handles just as before so I am convinced its the brakes.
What do I check next??
