weegie
a little input would be helpful. 69 vette 350/350 with a blockage or lack of flow. new temperature sensor,new thermostat and guage is working according to the potentiometer i put on it.The ohms on the sensor also appear to be correct . The problem is the car will only warm up to about 150.deg on the guage.I dropped in another 195 deg.thermo and it worked for about 40 mi.or so then it went back to the 150 deg.mark again.there appears to be flow in the radiator but I feel nothing in the top hose at all.If there is an airlock how do you get it out ? I heard some people drill a small hole 1/16 or so in the thermo. and it will slowly work itself out.
