Help! 69 wiper wiring/blower motor
hoso
australia
1969 black
Hi from Australia to all , Doe's anyone have a simplified diagram of the wiring for the wiper system and how to follow the ground to the blower motor as i understand it is ground thru this circuit , i have replaced the wiper switch and when turned on i can hear the solenoid click behind the dash , i am sure there is a bare terminal here , also a vacuum line is missing but i think that side i have sorted , wiper door is open as i have reversed the vacuum to the actuator . Starter has been replaced and i will be checking that the ground lead hasnt been hooked up to the positive terminal
Do you have the wiring diagram for your 69? If not, I can send you a copy of mine. When I run into an odd wiring problem I get out the highlighter pens and make each wire a different color so I can easily follow them from source to ground.
Tanks Tim , no i dont have a wiring diagram if you have a copy that you could email me that would be great my email is hoso49@gmail.com
