69 Won't Turn Over!
  • Thread starter Thread starter ernie d
E
ernie d
My 69 coupe (74 454 motor) all of a sudden does not turn over to start. Battery voltage checks fine, battery terminal connections are clean and secure. All fuses seem fine.
Started and ran fine, shut it off. Tried to restart 1 minute later, nothing.
What is your best guess on likely culprits?
Either a bad power or ground connection at the starter relay or a bad starter motor or a bad power connection or ground at the starter.
turn the key to run and jump the solenoid on the starter.also check for a bad fusible link. mike
Need more info...is it cranking, do you have spark, gas...???
