6MT Problem
Mike1320
Clarksville, TN
2004 MY 6-speed Convertible
:duh I used this one because I couldn't find "embarrassed". I missed a 1-2 shift yesterday and now the transmission doesn't shift the same. All the gears but 2nd are fine, and there are no leaks or unusual noises. When going into second, either up or down, it's harder to engage and sometimes crunches. Double-clutching helps, but it still isn't right. What did I do to it, and how much of the GNP is it going to cost me to fix it?
Thanks,
Mike
HI there,
You may have rounded the teeth of the 1/2 syncronizer hub.
Unfortunately, you will have to remove and disassemble the transmission.
However, first start off with a shifter adjustment, just to make sure.
Allthebest, c4c5
