H
HighlyFanatic
Im not sure if any of you have used car-test before. Anyways, I ran some numbers through....
using the 3.73 gears, 700R4 tranny, and the 400HP Streemaster (350 Stroker) engine offered by Speed-O-Motive.....
the 0-60 works out to 4.23 seconds
the 1/4 mile works out to 12.6 seconds @ i forgot what mph. im at school right now. YIKES!! *drooling*
for those of you that have it, here were the modifications I used.... (3282 lbs test weight, coefficient of drag 0.35, everything else is stock, except final drive gear of 3.73, and the 700R4 tranny numbers)
http://www.speedomotive.com/400 H.P. STREET MASTER ENGINE CHEVY 350 STROKER.htm
